帖子主题: 文章分享
发帖:141
经验:46
勋章:6
发表于:2019-11-05 16:52:50
只看该作者 点击:583 回复:4    楼主
春江花月夜
作者:张若虚 唐代 赏析
春江潮水连海平,海上明月共潮生。滟滟随波千万里,何处春江无月明!江流宛转绕芳甸,月照花林皆似霰。空里流霜不觉飞,汀上白沙看不见。江天一色无纤尘,皎皎空中孤月轮。江畔何人初见月?江月何年初照人?人生代代无穷已,江月年年只相似。不知江月待何人,但见长江送流水。白云一片去悠悠,青枫浦上不胜愁。谁家今夜扁舟子?何处相思明月楼?可怜楼上月徘徊,应照离人妆镜台。玉户帘中卷不去,捣衣砧上拂还来。此时相望不相闻,愿逐月华流照君。鸿雁长飞光不度,鱼龙潜跃水成文。昨夜闲潭梦落花,可怜春半不还家。江水流春去欲尽,江潭落月复西斜。斜月沉沉藏海雾,碣石潇湘无限路。不知乘月几人归,落月摇情满江树
我想做个好人
发帖:1206
经验:1199
勋章:4
发表于:2019-11-13 08:32:18
好文章
发表于:2019-12-06 14:20:55
liner hanger system
select a reamer shoe
ultra high pressure cement head
what is liner hanger
bow springs centralizer pc type
cement head
cement heads
cement swivel manufacture
cement swivel manufacturer
centralizer
cossover sub
double plug cement head
drill pipe centralizer
dyx a hydraulic liner hanger
edg a mechanical liner hanger
expandable liner hanger
float collar float shoe
non rotating type float collar float shoe
stab in type float collar float shoe
float shoe float collar
High Pressure Cement Head
hinged non welded bow spring casing centralizer
hinged non welded bow spring centralizer
hinged non welded positive casing centralizer
hinged welded bow spring centralizer
liner hanger
liner hanger packer
liner hangers
oilfiled equipment factory
oversea project service
reamer shoe
rotating cement head
single plug cement head
slip on semi rigid welded bow spring centralizer
slip on single piece bow spring centralizer
slip on stand off band centralizer
slip on welded bow spring centralizer
slip on welded bow spring turbolizer
slip on welded positive casing centralizer
slip on welded positive spirolizer
slip on welded straight cage rigid centralizer
spiral vane aluminium solid rigid centralizer
spiral vane composite centralizer
spiral vane roller composite centralizer
spiral vane roller steel solid rigid centralizer
spiral vane steel solid rigid centralizer
ssx a liner-hanger
stage cementing collar
straight vane aluminium solid rigid centralizer
straight vane composite centralizer
straight vane roller centralizer
syx a liner hanger
xgj a mechanical liner hanger
xgs a hydraulic liner hanger
发帖:43170
经验:51643
发表于:2020-01-13 04:33:06
学习了
发帖:141
经验:46
勋章:6
发表于:2020-01-15 14:58:30
回复:1楼qylm029的帖子
具有审计师(统计师、财政税务专业经济师)等会计相关资格转升或转评高级会计师应具备的条件:1、取得高级审计师、高级统计师等高级资格3年(含3年)以上,目前在会计或会计管理岗位上,有会计工作业绩和成果,可以按照条件申请转评高级会计师。
2、目前在会计岗位上,并取得审计师、统计师、财政税务专业经济师等资格5年(含5年)以上的申报人员,其从事审计、统计等会计相关工作的年限可以连续作为会计工作年限计算,正常申报高级会计师。
我想做个好人
文章分享
